Chino Valley, AZ – OR-Fab’s new HDX full-width Jeep winch bumper combines heavy-duty trail protection with a slim, aggressive appearance. The HDX front bumper fits 2007 thru 2014 model Jeep JK Wranglers, and is constructed from precision laser cut 3/16-inch thick steel plate. The bumpers are CNC press-brake formed and hand welded, providing the highest quality and fitment available, as well as easy installation into the OE bumper mounts.
The OR-Fab HDX front bumper improves the Jeep’s appearance, and extends from wheel-to-wheel. The tapered design withstands serious trail abuse and easily slides off rocks. The up-swept edges maximize approach angles and provide clearance with up to 37-inch diameter tires. A recessed winch mount provides greater airflow to the radiator and the 2.5-inch diameter grille hoop has light tabs for auxiliary lights. The bumper also features mounting holes that fit aftermarket or OE fog lights, as well as heavy-duty welded D-ring mounts for the two included D-rings.
OR-Fab’s HDX front bumper fits center-mounted winches (PN 83260) or can be used with offset winches (PN 83261). Both are available in a black heavy-duty wrinkle or gloss finish. For more information, contact OR-Fab, P.O. Box 3450, Chino Valley, AZ 86323, (928) 636-7080. Visit them on the web at www.orfab.com.
