Trail Master Suspension - Ford Applications - - Off-Road.com
Price and Compare Vehicles:
New, Used, and Powersports    Go button
ORC STAFF
Off-Road.com
CORONA, Cal. -- Trail Master Suspension, a leader in independent front suspension technology and development meets the consumer needs with suspension lift systems available for many 1980 through 2000 2WD and 4WD Ford applications, including the F150, F250, F350, Bronco, Ranger and Expeditions.
Trail Master's FB120 4" lift for 1998 - 2000 Ford Ranger features Trail Master's patent pending Dual Rack Steering System design incorporating a second horizontal steering shaft connected to the OE shaft via new bracketry. This design lowers the steering system without major modifications. The result is uncompromised steering geometry identical to stock.
Trail Master's system includes a choice of shock absorbers in three different designs, specifically matched to the application. Bracketry is powder coated in Trail Master's unique silver vein finish for good looks and greater durability. Each system is complete with all necessary components and hardware for bolt-on installation. Illustrated instructions and a limited lifetime warranty complete this system.
Also available, the FB124 4" lift for 1998 - 2000 Ford Explorer with the following features and benefits:
  • Includes integrated crossmembers to connect driver and passenger side bracketry
  • Drops differential with new bracketry a full 4" to keep driveline geometry at factory specs
  • Features patented dual rack steering system incorporating second horizontal steering shaft connected to the OE shaft via replacement bracketry
  • Includes torsion bar drop brackets
  • Includes replacement 4" lift rear leaf springs
  • Includes replacement rear lateral shock
  • Includes choice of shock absorbers; SSV Speed Smart or Invader SS hydraulic
  • Recommended tire size up to 32" diameter
  • Will fit 4 wheel drive vehicles. Does not fit all wheel drive models
  • Limited Lifetime Warranty
  • Vehicles with CV style front driveshaft may require front driveshaft replacement (#CVDS47) to minimize vibration
  • Optional skid plate available (#8094). Extends OE skid plate.
Trail Master Suspension systems are complete systems! One part number for one complete system at one great price . . . containing everything you need for faster, simplified installation. Each system is complete with all necessary components, shocks, hardware and fasteners for easy installation, including comprehensive illustrated instructions.
Trail Master's tech line is (909) 736-8686. They can answer more questions or you may write to Trail Master Suspension at 395 Smitty Way, Suite 200, Corona, California 92879. Or simply log onto the Trail Master Suspension Web Site.
post a comment
Your email address will NOT be published.
appears with your comment
read our privacy policy
Note: does not support HTML
All comments submitted are subject to review, and may be delayed before posting. We reserve the right not to post comments.
Untitled Document
Off-Road Videos -
ATV Reviews -
Enewsletters
Stay on Top of All the Action:
Sign up for Off-Road.com's Enewsletters
Source: Off-Road.com,
Click here
